sat_in
Aug 03, 2011Aspirant
Network Issues in ISCSI
Hello, I have a dell poweredge 2950 server with 2 NIC Cards. One is connected to LAN and other is connected to ISCSI network. The NIC on the Server thats connected to ISCSI network has below networ...
greyt
Aug 05, 2011Aspirant
sat_in wrote: spot on. it comes back online after i did exactly what you said. so what is the problem?
is it the NIC thats faulty?
i doubt it as i even swapped the IP addressess on the two NICs and the issue followed the IP 172.16.10.50
I would recommend one of the following options :-
1) Ideally enable flow control on your NICs and on the switch, this will mitigate the issue.
2) Open a case with Netgear and feel free to reference my case 15895782 which is for an identical issue.
Note that not all NICS and switches support flow control......
