Jens3
Nov 01, 2016Aspirant
New chassi, old drives, no volume
Hi! I've just recieved a warranty replacement chassi for my RN204-system. (The old unit was dead and gone due to a failed power unit.) Before I sent off the old unit I removed and marked the dri...
- Nov 01, 2016
You can normally just migrate the drives. So something bad must have happened when the power supply failed - likely some writes queued up that never got written to the disks..
You could contact support again, they might be able to mount the drives for you. But if the raid array isn't quite in sync there could be some corruption of the files. I'd just bite the bullet and start the rsyncs going.
Jens3
Nov 02, 2016Aspirant
Thank you StephenB, you confirmed my suspicions.
New volume created, rsync started from scratch. All is well.
(Well ... all but my own patience ... :smileywink: )
Thanks again!
FramerV
Nov 03, 2016NETGEAR Employee Retired
Hi Jens3,
Thanks for your feedback.
Feel free to post any suggestions, questions, recommendations or anything about your NAS that you think needs attention or will help others.
