Ashk
Nov 19, 2018Aspirant
New compatible 3TB hard drive not detected by Ready Nas 2-Bay RN212
Hi, I have just newly purchased a readynas 212 2-bay diskless along with compatible 3TB hard drives (WD30EFRX) however when going through the setup the ReadyNas says it is unable to detect the hard ...
- Nov 19, 2018
Hi Ashk
It would be best to get it replaced by the seller since it's brand new. I would not advise taking chances to make it work and since it's not getting detected then there's nothing to do anymore.
most likely mishandling is the cause or just unfortunate timing. :(
Hope this helps!
Regards
Marc_V
Nov 19, 2018NETGEAR Employee Retired
Hi Ashk
Welcoime to the Community!
Were you able to check if the drives work when connected to a Computer? this is just to check if there's any issue with the drives. It is also possible that the NAS SATA connections are not working, if this is brandnew I would recommend returning it to the reseller for a replacement.
It is also possible that the drives are not properly inserted on the NAS. Please see Adding disk to Desktop ReadyNAS
Hope this helps!
Regards
Ashk
Hi Marc,
Thank You for your reply, I did check the drives by connecting them to the computer they do not appear discoverable, I just tested another smaller 160GB drive into the NAS which has been detected. It is hard to believe the that 2x 3TB could be faulty, or is there a way to get these drives to appear in disk management or the NAS system?
Regards
Ash
