railstop1
Jan 17, 2013Aspirant
New drive installed, not expanding
I installed a WD Red 2TB in place of my failing 1TB Seagate. the resync went fine, but it isn't expanding the volume. It has been about 24 hours. I have rebooted it a few times. I have done this with ...
ReadySECURE
Jan 17, 2013Apprentice
Thanks for the logs.
disk!!1!!status=ok::descr=Channel 1: WDC WD20EFRX-68AX9N0 1863 GB, 33C/91F
disk!!2!!status=ok::descr=Channel 2: WDC WD10EADS-00M2B0 931 GB, 38C/100F
disk!!3!!status=ok::descr=Channel 3: Seagate ST3750330AS 698 GB, 38C/100F
disk!!4!!status=ok::descr=Channel 4: WDC WD10EADS-00L5B1 931 GB, 35C/95F
disk!!5!!status=ok::descr=Channel 5: WDC WD10EARS-00Y5B1 931 GB, 35C/95F
disk!!6!!status=ok::descr=Channel 6: WDC WD5000AADS-00S9B0 465 GB, 32C/89F
You have 6 disks in the unit according to the NAS.
Only 1 is 2 TB. You need 2 2 TB disks to expand the volume. I recommend replacing the 465 GB with a 2 TB or the 750 GB with a 2 TB. Try to get rid of smaller disks.
Data volume 3
md4 : active raid5 sde5[0] sdb5[3] sda5[4] sdd5[1]
732560448 blocks super 1.2 level 5, 64k chunk, algorithm 2 [4/4] [UUUU]
Data volume 2
md3 : active raid5 sda4[5] sdd4[4] sde4[3] sdc4[7] sdb4[6]
976747264 blocks super 1.2 level 5, 64k chunk, algorithm 2 [5/5] [UUUUU]
Data volume 1
md2 : active raid5 sda3[8] sdf3[5] sde3[6] sdd3[7] sdc3[10] sdb3[9]
2418323520 blocks super 1.2 level 5, 64k chunk, algorithm 2 [6/6] [UUUUUU]
Swap partition:
md1 : active raid6 sda2[8] sdf2[5] sde2[6] sdd2[7] sdc2[10] sdb2[9]
2096896 blocks super 1.2 level 6, 64k chunk, algorithm 2 [6/6] [UUUUUU]
Operating system:
md0 : active raid1 sda1[8] sdf1[5] sde1[6] sdd1[7] sdc1[10] sdb1[9]
4193268 blocks super 1.2 [6/6] [UUUUUU]
Device : /dev/md0
Create Time : 1317691562
Update Time : 1358449040
RAID Level : 1
RAID Capacity : 4193268
Disk Size : 4193268
Chunk Size : 0
Disks : 6
RAID Disks : 6
Active Disks : 6
Working Disks : 6
Failed Disks : 0
Spare Disks : 0
State : 0 [ ]
Disk Device RAID Disk Maj/Min Sectors State
5 /dev/sdf1 5 8/81 8388608 6 [ Active Sync ]
6 /dev/sde1 4 8/65 8388608 6 [ Active Sync ]
7 /dev/sdd1 3 8/49 8388608 6 [ Active Sync ]
8 /dev/sda1 0 8/ 1 8388608 6 [ Active Sync ]
9 /dev/sdb1 1 8/17 8388608 6 [ Active Sync ]
10 /dev/sdc1 2 8/33 8388608 6 [ Active Sync ]
Device : /dev/md1
Update Time : 1358443558
RAID Level : 6
RAID Capacity : 2096896
Disk Size : 524224
Chunk Size : 65536
Disks : 6
RAID Disks : 6
Active Disks : 6
Working Disks : 6
Failed Disks : 0
Spare Disks : 0
State : 1 [ Clean ]
5 /dev/sdf2 5 8/82 1048576 6 [ Active Sync ]
6 /dev/sde2 4 8/66 1048576 6 [ Active Sync ]
7 /dev/sdd2 3 8/50 1048576 6 [ Active Sync ]
8 /dev/sda2 0 8/ 2 1048576 6 [ Active Sync ]
9 /dev/sdb2 1 8/18 1048576 6 [ Active Sync ]
10 /dev/sdc2 2 8/34 1048576 6 [ Active Sync ]
Device : /dev/md2
RAID Level : 5
RAID Capacity : 2418323520
Disk Size : 483664704
Chunk Size : 65536
Disks : 6
RAID Disks : 6
Active Disks : 6
Working Disks : 6
Failed Disks : 0
Spare Disks : 0
State : 0 [ ]
5 /dev/sdf3 5 8/83 967331825 6 [ Active Sync ]
6 /dev/sde3 4 8/67 967331825 6 [ Active Sync ]
7 /dev/sdd3 3 8/51 967331825 6 [ Active Sync ]
8 /dev/sda3 0 8/ 3 967331825 6 [ Active Sync ]
9 /dev/sdb3 1 8/19 967331825 6 [ Active Sync ]
10 /dev/sdc3 2 8/35 967331825 6 [ Active Sync ]
Device : /dev/md3
Create Time : 1317700264
Update Time : 1358449035
RAID Level : 5
RAID Capacity : 976747264
Disk Size : 244186816
Chunk Size : 65536
Disks : 5
RAID Disks : 5
Active Disks : 5
Working Disks : 5
Failed Disks : 0
Spare Disks : 0
State : 0 [ ]
3 /dev/sde4 3 8/68 488375959 6 [ Active Sync ]
4 /dev/sdd4 4 8/52 488375959 6 [ Active Sync ]
5 /dev/sda4 0 8/ 4 488375959 6 [ Active Sync ]
6 /dev/sdb4 1 8/20 488375959 6 [ Active Sync ]
7 /dev/sdc4 2 8/36 488375959 6 [ Active Sync ]
Device : /dev/md4
Create Time : 1325480226
Update Time : 1358443392
RAID Level : 5
RAID Capacity : 732560448
Chunk Size : 65536
Disks : 4
RAID Disks : 4
Active Disks : 4
Working Disks : 4
Failed Disks : 0
Spare Disks : 0
State : 1 [ Clean ]
0 /dev/sde5 0 8/69 488375999 6 [ Active Sync ]
1 /dev/sdd5 1 8/53 488375999 6 [ Active Sync ]
3 /dev/sdb5 3 8/21 488375999 6 [ Active Sync ]
4 /dev/sda5 2 8/ 5 488375999 6 [ Active Sync ]
Data volume 3
Data volume 2
Data volume 1
Swap partition:
Operating system:
Device : /dev/md0
RAID Level : 1
Disk Size : 4193268
Chunk Size : 0
Disks : 6
RAID Disks : 6
Active Disks : 6
Working Disks : 6
Failed Disks : 0
Spare Disks : 0
State : 0 [ ]
Device : /dev/md1
RAID Level : 6
Disk Size : 524224
Chunk Size : 65536
Disks : 6
RAID Disks : 6
Active Disks : 6
Working Disks : 6
Failed Disks : 0
Spare Disks : 0
State : 1 [ Clean ]
Device : /dev/md2
RAID Level : 5
Chunk Size : 65536
Disks : 6
RAID Disks : 6
Active Disks : 6
Working Disks : 6
Failed Disks : 0
Spare Disks : 0
State : 0 [ ]
Device : /dev/md3
RAID Level : 5
Chunk Size : 65536
Disks : 5
RAID Disks : 5
Active Disks : 5
Working Disks : 5
Failed Disks : 0
Spare Disks : 0
State : 0 [ ]
Device : /dev/md4
RAID Level : 5
Chunk Size : 65536
Disks : 4
RAID Disks : 4
Active Disks : 4
Working Disks : 4
Failed Disks : 0
Spare Disks : 0
State : 1 [ Clean ]
