wreckedem1
Apr 04, 2014Aspirant
New drive showing dead, but its not
I had a WD drive going bad, and swapped with the exact model. Frontview kept showing it as dead, and Smart+ is greyed out. The logs, however, show the volume will be rebuilt and the front display has ...
Apr 04, 2014Guru - Experienced User
Are you hot-inserting? If not, maybe try that.
