Kaleem's avatar
Kaleem
Newbie - Novice requires Setup Advice
Hi,
I'm a complete novice when it comes to NAS, Raid, etc, however have bought some kit, so would like some advice on the best setup for what I want to primarily use, which is:
i) Media Streaming (to different devices locally and remotely)
ii) Document store (access locally and remotely)
iii) Back Up (local PC as well as any content stored directly on the NAS)
Kit:
ReadyNas NV +V2 (disk less)
2 x 3TB Seagate HDD
I'm running a Win7 setup with a Netgear Gigabit wireless router.
Now I have a 2 other drives with media content on them already, a 1.5TB, and 2TB. I plan on adding content onto 1 of the new 3TB drives as well.
What should I do?
1) Install 2 x 3TB, so that I have 3TB to store content and 3TB for mirror/backup
2) Install all 4 hard drives (1.5TB, 2TB, 3TB, 3TB) - understand that I will have to take content off and transfer back, I can't just plug and play?
3) Option 1) and leave the 1.5TB and 2TB drives as standalone USB drives, attaching to ReadyNas for media streaming, etc
I'm picking up knowledge slowly, but seems to me that the logical steps are to keep adding the largest drives possible so that the overall volume increases in size? I could be wrong.
Also how long am I looking at installation of the 3TB disks?
Thanks
Kaleem
  • The WD Red label drives come in three sizes, 1, 2 and 3TB models. They are respectfully, the WD10EFRX, WD20EFRX and WD30EFRX. They have found a market with a pent up demand for a reliable consumer based NAS drive, and as such are currently in short supply and high pricing. Hopefully, as production ramps up, they will become more plentiful and prices will drop.
  • Looks like I'm going to cancel the other 2 X 3TB's for now....you guys are scaring me with all these clicking noises !!!!!
    I may just end up with another 2 x 9YN166-500 type drives !!!!! Let me check with Seagate with regards to my existing drives.
    Would there be an issue in adding one of them (the non-9YN166-500 type drive), and adding WD Red Label's as the others for X-Raid Expansion?
    Or should i just stick with one brand at that start?
    I may just get end with another 2 x 9YN166-500 type drives.
    Let me check with Seagate with regards to my existing drives, would there be an issue in adding one of them (the non-9YN166-500 type drive), and adding WD Red Label's as the others for X-Raid Expansion?
    They aren't the best drives, they are more than adequate and supported though. I'm currently using 8 of them across 2 NV+ V2 and a USB dock. They are a good price so having a 3rd shouldn't be a big investment. And it will get double your available capacity for that investment.
    The firmware upgrade isn't complicated on Windows, and if you get another drive just ask them for CC4H or newer. You can see it written on the front of the drive.
    If you set up the NV+ V2 with a 3rd Seagate drive, you'll have a readily available backup solution using a USB dock connected to the NAS (or a drive in a dedicated enclosure if that's what you already have). You can then set up backups in Frontview and have the comfort of knowing the RAID will keep your data secure and the backup is available in the event of something dramatic. Keep one of the backup drives at a friends place if you can, that will mean you have it available in the event of a flood, fire, etc.
    This is from another newbie... I've had a Promise NAS for years and only recently added the Netgear enclosures. I'm impressed with them so far and the community here is great.
    /Peter
    I've got two of these HDDs in my Ultra2+ and I can't say I've heard any loud clicking noise, before or after upgrading the FW on the drives. Working fine for me.
  • Before the FW update my drive made an audibly head parking "click" noise about once a minute. But it's in a caddy in the main PC with air holes in, so it's very likely that this means it's a lot louder than it would be if buried in the case of the PC.
    Since the update it makes the same "chirping" noise others have mentioned. It sounds like a drive doing a quick random seek once every minute or so for long periods. However, the SMART values are fine, and the drive is working flawlessly. Also, performance has improved a lot with the update, so now i've just gotten used to it "chirping" away in the background.
    I did read somewhere that the drive has a feature built into the firmware that randomly tests every sector on the drive at random intervals on a cycle, to enable early notification of failure. But as this wasn't from an official source, it may or may not be the case.
ProSupport for Business
