MartinD1
May 16, 2013Aspirant
Newbie - ReadyNas Ultra 4 Boot Problems - case #21158089
Hi all. I took delivery of a readynas4 ultra today, from a friend where I know it was working. I've spent a good number of hours today trying to get this thing working with little to no luck. Here'...
mdgm-ntgr
May 16, 2013NETGEAR Employee Retired
Maybe one of the disks has failed.
Can you power down, remove the disks (label order), connect them to an internal SATA port in your PC and check them (e.g. Using SeaTools for SeaGate disks)?
Or failing that try a factory default with one disk removed. If that doesn't work, put the disk back in and try removing another one then doing a factory default...
You may also wish to check that the memory is properly seated. It can come loose in shipment. You may wish to run the memory test.
