MartinD1
May 16, 2013Aspirant
Newbie - ReadyNas Ultra 4 Boot Problems - case #21158089
Hi all. I took delivery of a readynas4 ultra today, from a friend where I know it was working. I've spent a good number of hours today trying to get this thing working with little to no luck. Here'...
mdgm-ntgr
May 16, 2013NETGEAR Employee Retired
If a factory default with just your spare disk installed works that suggests you may have a problem disk.
If the factory default with a spare disk works check what firmware version is running on the NAS and update it if it is an old version.
What brand and model disks are you using?
