MartinD1
May 16, 2013Aspirant
Newbie - ReadyNas Ultra 4 Boot Problems - case #21158089
Hi all. I took delivery of a readynas4 ultra today, from a friend where I know it was working.
I've spent a good number of hours today trying to get this thing working with little to no luck. Here's a rundown:
1) Plugged in, powered on. Screen sits at "Booting..." for ever and a day.
2) Moved drives around, still sits at "Booting...".
3) Raidar finds the device most of the time and will show it as 'booting'. I've left it in this state for up to 45 minutes to no avail.
4) Factory Reset - sits at "Testing Disks for ages" and Raidar shows the devices in status "Testing Disks" and the 4 green LED's are flashing under the drives in Raider. Prior to this, the screen on the NAS did show testing percentage right up to 100% then sat back at "Testing Disks..."
I'm at a complete loss... and I've been sitting with this on testing disks for the best part of an hour now.
Any help or advice is greatly appreciated!
Martin
Martin
- MartinD1AspirantBit of an update.
I tried the factory reset with just 1 drive, the 250gb one. It appeared to go well but then hung on "Booting".
I've now tried it with 2 of the Caviar Green's. The setup ran okay, I saw it installed and then I saw it creating the volume. It rebooted and sat at 'Booting...' for a while with led 2 flashing. That's now stopped flashing and led 1 is flashing. It still says 'Booting..' on the screen and Raidar is not picking up anything. - MartinD1AspirantUpdate 2:
It just hung at 'Booting...' so I powered down and replaced drive 1 with another drive. Booted back up. It then rand a Root FS check then jumped backed to "booting...". This was confirmed with Raidar.
As of a few minutes ago, the NAS is still sitting at "Booting.." with raidar showing no drives present and no Model.
Getting a bit fed up now :( - MartinD1AspirantJust happened to catch something on the NAS display when it was doing an install there (XRaid). It said "ERR: Could not properly extract.." and straight away went to "Create C: blah%"
Any idea what that is? - MartinD1Aspirant~Pulled 2 drives and put them in my own pc, checked them over with smart and WD LifeDiagnostics, write zero's to the drive (quick erase) and I'm trying again.
Saw the same "could not extract" error flash up but it's creating a volume now so fingers crossed.... :? - MartinD1AspirantI've managed to gain access to the NAS via Telnet.
I can see that the drives are recognised by the system and are displaying correctly with sfdisk... however, I can't seem to find anything relating to 'frontview' at all apart from a log file in /var/log/frontview/
Is this thing completely screwed? - MartinD1AspirantJust on the offchance a staff member can help I've updated the topic with the case number #21158089
- siignaNETGEAR Employee RetiredIt almost sounds like the on-board flash might be giving you some problems. I went ahead and pulled your case into my queue, I'll follow-up with you through the ticket system. ;)
- MartinD1AspirantHi Siigna
Thanks for doing that :) I've responded to your last request for info. Just so you know I've gone ahead and bought new drives which should be arriving in the next few hours so if we can't get it working I have spanking new drives that can be used for testing too. - MartinD1AspirantI've tried it now with 2 brand new drives... and still have the same problem unfortunately.
Same error as before "ERR: Could not extract properly..." then it sits in a 'Booting...' loop. - mdgm-ntgrNETGEAR Employee RetiredThat suggests the problem is with the on-board flash as siigna mentioned.
You could try a USB Boot Recovery: Unofficial ReadyNAS USB Recovery Guide for x86-based Systems
Put 4.2.22 (http://www.readynas.com/RAIDiator_x86_4_2_22_Notes) on the USB key rather than 4.2.15
After doing a USB Boot Recovery try another factory default
