eregalini
Sep 10, 2012Aspirant
Newbie: can't see NAS in Wifi connection
Hallo, I just bought a Duo v2 and attached it with a cable to my home network (DG3700 router) and installed the software on a Win7 PC. Now in Explorer I can properly see the NAS listed only if the PC...
Sep 11, 2012Guru - Experienced User
What OS are you running on the PC?
Also, can you access the NAS anyway (either through through the dashboard, or by entering \\NASname or \\xxx.xxx.xxx.xxx in the explorer address bar (xxx's are the NAS IP address).
Can RAIDar see the Duo?
