eregalini
Sep 10, 2012Aspirant
Newbie: can't see NAS in Wifi connection
Hallo, I just bought a Duo v2 and attached it with a cable to my home network (DG3700 router) and installed the software on a Win7 PC. Now in Explorer I can properly see the NAS listed only if the PC...
eregalini
Sep 11, 2012Aspirant
Hi Stephen, thanks for your suggestions. Here is the situation:
- I am running a PC with windows 7 pro 64bit
- RAIDar cannot find the NAS if the PC is connected only via wifi and the same happens if I try to connect with \\NASNAME or \\xxx.xxx.xxx.xxx;
- on the contrary, the dashboard works properly, letting me work on the configuring it without any problem.
How can I then access the data stored on the NAS when I am in wifi?
Thanks
Thanks
