eregalini
Sep 10, 2012Aspirant
Newbie: can't see NAS in Wifi connection
Hallo, I just bought a Duo v2 and attached it with a cable to my home network (DG3700 router) and installed the software on a Win7 PC. Now in Explorer I can properly see the NAS listed only if the PC...
Sep 11, 2012Guru - Experienced User
Is the WiFi connection type "public"? If so, try changing it to "home" or "work".
