eregalini
Sep 10, 2012Aspirant
Newbie: can't see NAS in Wifi connection
Hallo, I just bought a Duo v2 and attached it with a cable to my home network (DG3700 router) and installed the software on a Win7 PC. Now in Explorer I can properly see the NAS listed only if the PC...
Sep 13, 2012Guru - Experienced User
What happens if you use \\ipaddress?
Also, is your WiFi base station the same as your router? Or are you using a separate device to provide WiFi? If you do have a separate device, you might be double-routing which would explain the behavior.
