eregalini
Sep 10, 2012Aspirant
Newbie: can't see NAS in Wifi connection
Hallo, I just bought a Duo v2 and attached it with a cable to my home network (DG3700 router) and installed the software on a Win7 PC. Now in Explorer I can properly see the NAS listed only if the PC...
eregalini
Sep 14, 2012Aspirant
YESSSSSSSSS! You are right, I have in fact two routers: my wifi network is created with a Netgear DGND3700, which is connected to another modem/router (without wifi) given by my internet service provider.
I now tried to connect the readyNAS to the DGND3700 and everything works fine, thanks a lot.
Do you know if there is a way to configure the DGND3700 so that it only works as wifi access point without conflicting with the other router?
