Pixeltje
Jul 21, 2011Aspirant
NFS issue with OSX (not lion) and NV+
Hi, I'm having some difficulties setting up nfs acces to my NV+. I can start NFS and set a number of threads (what is this? value set to one..) but it doesn't show in Finder. AFP and CIFS share w...
Pixeltje
Okay, i'm back from work and confused. Please look at the screenshots below..
First; when i enable NFS, i'm able to set a number of ' NFS threads' (as shown on image), what does that mean?
Then, when i've enabled NFS and go to the shares-list to edit the preferences, this is what's there;
These are the options available under the NFS tab;
The .0.2 address is my mbp. Since the screenshot is in Dutch, I'll translate it for you:
top right corner (drop down list): ' standard acces' set to Disabled
First of three fields: Read only hosts: <empty>
Second: Hosts with write permissions: <my IP>
Third: Hosts with Root acces: <my IP>
Then under the "advanced" tab:
And Finder shows:
So it works :)
I'd like to know whether or not it's possible to make finder remind this share, so when i get back home, it automatically detects it's there and adds it to the Finder list.
Would you recommend any changes to this setup?
Thanks a lot for your time and knowledge :)
And Finder shows:
So it works :)
