fab1378
Dec 03, 2014Aspirant
NFS shares not available in XBMC since 6.2.0
Hi All, After I upgraded to 6.2.0 on my Readynas 102, I cannot connect to my shares via NFS, which used to work in 6.1.9. I can only connect using SMB. My XBOX installation is running on Android ...
mdgm-ntgr
Dec 03, 2014NETGEAR Employee Retired
Do you get an error message when trying to connect?
What versions of NFS do you have enabled on the NAS? Can you disable NFSv4 if that is enabled?
