fab1378
Dec 03, 2014Aspirant
NFS shares not available in XBMC since 6.2.0
Hi All, After I upgraded to 6.2.0 on my Readynas 102, I cannot connect to my shares via NFS, which used to work in 6.1.9. I can only connect using SMB. My XBOX installation is running on Android ...
ZkiiFreak
Dec 21, 2014Aspirant
I second this!
Problem is a little cloudy; it is not "advertising" shares over NFS. It is possible to get files via NFS from XBMC. I know that because I added the files to the XBMC library pre-6.2.0 and they are still accessible from XBMC. Problem is only when you in XBMC want to add new locations. Then the NAS does not show up as an NFS server. SMB and SAMBA seems to advertise themselves: This is evident when using the Zeroconf browser in XBMC.
So, in my conclusion, the problem might be on the NAS and the "advertisement" (pleeeeeease, tell me what the correct word is :) ).
Funny thing is, that if I use the showmount cmd from an RPi with XBMC:
As you can see, NFSv4 is enabled on the NAS.
Please also see my post on Kodi forum (formerly known as XBMC) http://forum.kodi.tv/showthread.php?tid ... pid1867014
Problem is also present in XBMC on Windows.
Can someone shed some light on the subject?! Please
Thanks!
xbian@xbian ~ $ sudo showmount -e 192.168.0.2
[sudo] password for xbian:
Export list for 192.168.0.2:
/data/Videos *
/run/nfs4/data/Videos *
/data/Pictures *
/run/nfs4/data/Pictures *
/data/Music *
/run/nfs4/data/Music *
/run/nfs4/data *
/run/nfs4 *
/data/media 127.0.0.1
/run/nfs4/data/media 127.0.0.1
/data/Backup 127.0.0.1
/run/nfs4/data/Backup 127.0.0.1
Thanks!
