eggamull
Nov 12, 2017Tutor
NIC speed of NV 102
OS 6.9.0, 2 HDD 4TB, RAID 1 RN10224D NIC works only on 100 MBit how to force switching to 1Gbits/sec?
- Nov 14, 2017
There was a contact stuck inside the RJ45 socket. Now NIC works as before...
Nov 12, 2017Guru - Experienced User
If you are connected to a gigabit switch or router, then the next step is to try a different cable. If some of the wires in the cable aren't connected properly then autonegotiation can fail.
- eggamullNov 13, 2017Tutor
Hi Stephen, sorry not mentioning it; i did that basic things already: changing switch, router, cable. What aI did latest before the problem was installing Plex-App on NAS.
Thanks anyway
br Albrecht
- eggamullNov 14, 2017Tutor
