antaljanssen
Oct 26, 2017Aspirant
NIC teaming on RN314
My RN314 runs on the latest FW and has a dual Link to a Cisco Meraki Switch MS220 capable of L3, LACP, LAG, etc.! After creating the team on 802.3ad LACP Layer 3+4 in the RN314 it states ok but after...
- Mar 19, 2018
antaljanssen wrote:
In the meantime, I'm running on FW level 6.9.3 and the setting is stable but still, there is no data received over one of the two connections within the bond. One is constantly receiving 4Mbps data from 4 separate devices in total so it should be possible to use both ports with setting L3+L4, correct?
The L3+L4 setting only applies when sending. The switch LACP setting is what matters in the NAS receive direction. Most switches are hard-wired to use layer-2 hashing.
The odds of receiving streams from 4 devices on the same link is 1/8 - not that probable, but not shocking either. Using L3+L4 doesn't change those odds - what it does is potentially allow 2 streams going to the same device to use different links.
You might consider using a static LAG on the switch, and set up the NAS to use round-robin.
Tinyhorns
Oct 29, 2017Apprentice
Networking is so broken in 6.9.0.
LACP is not working.
People have reported issues with DHCP as well, and random disconnects.
I really wonder how this release ever made it though testing......
// T
[Sun Oct 29 21:54:49 2017] e1000e: eth0 NIC Link is Up 1000 Mbps Full Duplex, Flow Control: None [Sun Oct 29 21:54:49 2017] bond0: link status definitely up for interface eth0, 1000 Mbps full duplex [Sun Oct 29 21:54:50 2017] e1000e: eth1 NIC Link is Down [Sun Oct 29 21:54:50 2017] bond0: link status definitely down for interface eth1, disabling it [Sun Oct 29 21:54:50 2017] bond0: first active interface up! [Sun Oct 29 21:54:53 2017] e1000e: eth1 NIC Link is Up 1000 Mbps Full Duplex, Flow Control: None [Sun Oct 29 21:54:53 2017] bond0: link status definitely up for interface eth1, 1000 Mbps full duplex [Sun Oct 29 21:55:12 2017] e1000e: eth0 NIC Link is Down [Sun Oct 29 21:55:12 2017] e1000e 0000:01:00.0 eth0: speed changed to 0 for port eth0 [Sun Oct 29 21:55:12 2017] bond0: link status definitely down for interface eth0, disabling it [Sun Oct 29 21:55:12 2017] bond0: first active interface up! [Sun Oct 29 21:55:13 2017] e1000e: eth1 NIC Link is Down [Sun Oct 29 21:55:13 2017] e1000e 0000:04:00.0 eth1: speed changed to 0 for port eth1 [Sun Oct 29 21:55:13 2017] bond0: link status definitely down for interface eth1, disabling it [Sun Oct 29 21:55:13 2017] bond0: first active interface up! [Sun Oct 29 21:55:15 2017] e1000e: eth0 NIC Link is Up 1000 Mbps Full Duplex, Flow Control: None [Sun Oct 29 21:55:15 2017] bond0: link status definitely up for interface eth0, 1000 Mbps full duplex [Sun Oct 29 21:55:15 2017] bond0: first active interface up! [Sun Oct 29 21:55:16 2017] e1000e: eth1 NIC Link is Up 1000 Mbps Full Duplex, Flow Control: None [Sun Oct 29 21:55:16 2017] bond0: link status definitely up for interface eth1, 1000 Mbps full duplex [Sun Oct 29 21:56:07 2017] e1000e: eth0 NIC Link is Down [Sun Oct 29 21:56:07 2017] e1000e 0000:01:00.0 eth0: speed changed to 0 for port eth0 [Sun Oct 29 21:56:07 2017] e1000e: eth0 NIC Link is Up 1000 Mbps Full Duplex, Flow Control: None [Sun Oct 29 21:56:20 2017] e1000e: eth0 NIC Link is Down [Sun Oct 29 21:56:20 2017] e1000e 0000:01:00.0 eth0: speed changed to 0 for port eth0 [Sun Oct 29 21:56:20 2017] bond0: link status definitely down for interface eth0, disabling it [Sun Oct 29 21:56:20 2017] bond0: first active interface up! [Sun Oct 29 21:56:23 2017] e1000e: eth0 NIC Link is Up 1000 Mbps Full Duplex, Flow Control: None [Sun Oct 29 21:56:23 2017] bond0: link status definitely up for interface eth0, 1000 Mbps full duplex [Sun Oct 29 22:07:03 2017] e1000e: eth0 NIC Link is Down [Sun Oct 29 22:07:03 2017] e1000e: eth0 NIC Link is Up 1000 Mbps Full Duplex, Flow Control: None [Sun Oct 29 22:07:54 2017] e1000e: eth0 NIC Link is Down [Sun Oct 29 22:07:54 2017] e1000e 0000:01:00.0 eth0: speed changed to 0 for port eth0 [Sun Oct 29 22:07:54 2017] e1000e: eth0 NIC Link is Up 1000 Mbps Full Duplex, Flow Control: None
- antaljanssenNov 04, 2017Aspirant
Where can I find such logging as shown (see dump) here in my RN314?
