Jayau's avatar
Jayau
Follower
Jan 29, 2018
Link 2 GS748T switch with Microsoft NIC Teaming is set
Hi There,
I have Windows Server 2012 R2 with 4 NICs Teaming. I have 2 of GS748T switches. What is the best way to set it up (both hardware and software). Should I remove NIC Teaming and use LAG on the switch? Should all 4 cables plug-in same switch? If I use 1 cable to uplink to other one, the speed will be 1GB, right?
Appreciated the reply.
J
ProSupport for Business
