antaljanssen
Oct 26, 2017Aspirant
NIC teaming on RN314
My RN314 runs on the latest FW and has a dual Link to a Cisco Meraki Switch MS220 capable of L3, LACP, LAG, etc.! After creating the team on 802.3ad LACP Layer 3+4 in the RN314 it states ok but after...
- Mar 19, 2018
antaljanssen wrote:
In the meantime, I'm running on FW level 6.9.3 and the setting is stable but still, there is no data received over one of the two connections within the bond. One is constantly receiving 4Mbps data from 4 separate devices in total so it should be possible to use both ports with setting L3+L4, correct?
The L3+L4 setting only applies when sending. The switch LACP setting is what matters in the NAS receive direction. Most switches are hard-wired to use layer-2 hashing.
The odds of receiving streams from 4 devices on the same link is 1/8 - not that probable, but not shocking either. Using L3+L4 doesn't change those odds - what it does is potentially allow 2 streams going to the same device to use different links.
You might consider using a static LAG on the switch, and set up the NAS to use round-robin.
mdgm-ntgr
Oct 31, 2017NETGEAR Employee Retired
antaljanssen wrote:
but after the reboot of the RN314 it changes back to 802..3ad LACP layer 2 every time again?!
This should be fixed in the latest hot-fix. You could try rebooting your NAS. The hot-fix should be installed within 15 minutes or so after that. If you do nothing (i.e. don't reboot your box) it'll be installed within a week.
antaljanssen
Nov 04, 2017Aspirant
I'm on version 6.9.0 and there is no update as the GUI informs me. Multiple reboots don't change anything. Where can I find the fix?
- KimeraNov 08, 2017Guide
antaljanssen wrote:I'm on version 6.9.0 and there is no update as the GUI informs me. Multiple reboots don't change anything.
This idea, probably, is worth a read WRT the GUI not informing you about the Hot Fix patch level of your ReadyNAS OS GA version (6.9.0).
- antaljanssenMar 18, 2018Aspirant
- StephenBMar 19, 2018Guru - Experienced User
