AndyLen
May 14, 2016Aspirant
No access despite reset
I purchased my ReadyNAS Duo v1 and registered it back in 2010. I used it once or twice to back up the computer I was using back then. Just recently I decided to see what was on those 6 year old d...
- May 14, 2016
ok found the answer
for anyone else having this issue
after reset use;
admin
netgear1
netgear1 instead of password
(the latter is incorrect although it is on this page)
AndyLen
ok found the answer
after reset use;
admin
netgear1
bedlam1
May 14, 2016Prodigy
The link you have quoted above is for Readynas OS 6 (and relates to Raidator 5.3)
Your Duo V1 is probably running on Raidator 4.0
See this link http://kb.netgear.com/app/answers/detail/a_id/21438
- mdgm-ntgrMay 14, 2016NETGEAR Employee Retired
The Duo v1 can only run RAIDiator 4 and was replaced in our lineup back in 2011.
The last of the products that had the default password of 'netgear1' was discontinued back in 2013.Most of the articles refer to newer products than what you have.
