noahbucca
Nov 02, 2011Aspirant
No access from XP through CIFS
Hi, I have a NAS NV + envirronnement a professional. Access via the FrontView is OK, ftp access too, but I have no access from the PC running XP. Firmware version: 4.1.8 RAIDiator The IP addre...
Nov 05, 2011Guru - Experienced User
Works fine with my XP professional system and my Pro. XP is up to date on Microsoft security updates, and the pro is running 4.2.19.
Hyrax wrote: I'm having a similar problem with my ReadyNas Ultra 4, using firmware RAIDiator-x86, Version:4.2.19. Previously I could access all of my shares but within the last month I've done two things that may be causing the problem. I updated the Ultra from the 4.2.15 firmware to the current version and I updated XP with a lot of security updates. I'm not sure which update is causing the problem, but I believe it was the XP security updates.
I'm still looking for a solution to my problem, I'll post if I find anything.
