jad82
Sep 19, 2013Tutor
No Access over WiFi
Hi Guys, I purchased the ReadyNAS Duo v2 about a year ago. Everything worked just fine until (approx) 1 week ago. Wired connection still works great. The problem is trying to connect via wifi. ...
vandermerwe
Sep 19, 2013Master
Jad82
You are going to have to explain exactly how the NAS is connected to your lan, and how your iMac is connected to your lan.
Are they both connected to a router or a switch?
When you say you remove a cable, what cable do you mean? Is this the cable from the iMac to a router/ switch ?
This sounds very much like a network setup problem and the forum members will need morê details about this.
