jad82
Sep 19, 2013Tutor
No Access over WiFi
Hi Guys, I purchased the ReadyNAS Duo v2 about a year ago. Everything worked just fine until (approx) 1 week ago. Wired connection still works great. The problem is trying to connect via wifi. ...
jad82
Sep 19, 2013Tutor
Hi Guys,
My router is an zyxel F1000, it provides the wifi. I also have a 5 port Netgear switch.
The F1000 is connected to a switch. The NAS / iMac are then connected to that switch. When I removed the cable, I removed the cable that was connecting the iMac to the switch.
I'm not at home at the moment but I'll check the "AP Isolation" when I return home. I will also post the wifi settings.
Thanks guys. I'll report back
