jad82
Sep 19, 2013Tutor
No Access over WiFi
Hi Guys, I purchased the ReadyNAS Duo v2 about a year ago. Everything worked just fine until (approx) 1 week ago. Wired connection still works great. The problem is trying to connect via wifi. ...
Sep 20, 2013Guru - Experienced User
Network Setting > Wire
fastfwd wrote: If there's no setting called "AP Isolation", look for one called "Guest WLAN".
less > More AP has the "Guest WLAN" setting (page 79 here: http://broadbandsupport.eircom.net/down ... _F1000.pdf You need to set it to "disabled" to reach the wired LAN from your WiFi-connected devices.
