jad82
Sep 19, 2013Tutor
No Access over WiFi
Hi Guys, I purchased the ReadyNAS Duo v2 about a year ago. Everything worked just fine until (approx) 1 week ago. Wired connection still works great. The problem is trying to connect via wifi. ...
jad82
Sep 20, 2013Tutor
Thanks guys.
For those with the same router. Here's the solution
log into the modem, network settings > qos > class setup > EDIT RTSP and default from LAN to LOCAL, or just delete all settings in the QoS Class setup list
