Gazzacoop
Sep 10, 2017Tutor
No Admin Page and Power Button Reset Does not work.
My ReadyNAS admin page continually goes offline, when it does the buttons on the front do not work at all, the only way to get back into the admin page is to unplug the power cord and then plug it ba...
Sep 11, 2017Guru - Experienced User
Gazzacoop wrote:
I have read all forums and tried everything, what next?
Try downloading the log zip file.
Look in disk_info.log at the smart stats.
Also look in volume.log - scroll down to the bottom, and you'll see a section that looks like this:
=== df -h ===
Filesystem Size Used Avail Use% Mounted on
udev 10M 4.0K 10M 1% /dev
/dev/md0 4.0G 710M 3.0G 20% /
check to see if /dev/md0 is full.
Gazzacoop
Oct 01, 2017Tutor
Hi Stephen,
Here is my Volume Log,
== df -h ===
/dev/md0 3.7G 817M 2.7G 24% /
Here is my disk_info.log
Device: sda
Controller: 0
Channel: 0
Model: ST10000VX0004-1ZE101
Serial: ZA214AVR
Firmware: AV01
Class: SATA
RPM: 7200
Sectors: 19532873728
Pool: data
PoolType: RAID 1
PoolState: 1
PoolHostId: 601b366d
Health data
ATA Error Count: 0
Reallocated Sectors: 0
Reallocation Events: 0
Spin Retry Count: 0
End-to-End Errors: 0
Command Timeouts: 0
Current Pending Sector Count: 0
Uncorrectable Sector Count: 0
Temperature: 43
Start/Stop Count: 15
Power-On Hours: 2064
Power Cycle Count: 15
Load Cycle Count: 11841
Device: sdb
Controller: 0
Channel: 1
Serial: ZA213VNG
Firmware: AV01
Class: SATA
RPM: 7200
Pool: data
PoolType: RAID 1
PoolState: 1
Health data
ATA Error Count: 0
Spin Retry Count: 0
Command Timeouts: 0
Temperature: 42
Power-On Hours: 2039
Load Cycle Count: 11859
I am not sure what I am looking for?
- StephenBOct 02, 2017Guru - Experienced User
I wanted to see the disk health and the OS partition free space. Both look fine, so they are not the problem.
I used to have a similar problem with my RN102, and it was linked to Plex's rescan of the media library (looking for metadata). Perhaps try turning off plex for a couple of days, and see if the problem stops?
