Sinegraf
Jul 07, 2019Guide
no network after lightning strike
No network link no network activity lights USB backup works So disks and RAID systems work (Raid5 4x3TB now 4,2/8,1T free) So a simple solution could be to move the disks to a new 4Bay Read...
- Jul 21, 2019
Sinegraf wrote:
NV + v2 RAID had the latest available software for that model ..
Now I don't know if it meant X-RAID gibbrich ..
If it has X-RAID, it is probably the "writing order" that is special
the writing order can be affected by "parity delay"
Someone who knows if it is 100% normal (RAID5 standard) or a separate secret rule?Your NAS uses software RAID (mdadm). XRAID is layered on top of mdadm - it manages RAID groups for you automatically (which allows for expansion of the array). But underneath it is just mdadm - there is nothing proprietary about the on-disk structures.
FWIW, it sounds like R-studio isn't finding the mdadm superblock. It's possible that the superblock was corrupted when the lightning stuck. Though I'd have expected an error on the LCD panel if that were the case.
As I said earlier, I don't know what parameters are used when the array is created.
Sinegraf wrote:
can ReclaiMe manage NETGEAR NAS?
Folks have used it for OS-6 ReadyNAS (which uses the BTRFS file system). I don't recall seeing it used for OS-5, but it likely would work.
The free tool I pointed you too will only find the RAID parameters. The paid version is needed to recover files. However, you can alternatively download the paid version, and see if it can recovery anything before you actually purchase it.
You could also contact R-Studio support, they might know the parameters used by your NV+ v2.
Marc_V
Jul 07, 2019NETGEAR Employee Retired
Welcome to the Community!
Sorry to hear about that but it's good that you can do the USB backup, Have you checked if your switch or router is working where the NAS connects? Yes, if you are planning to upgrade your NV+ RN214 or better is a good choice, transferring the disks can be done by following these steps. If you want it to be plug and play for the disks, you may need to find a healthy NV+ online but upgrading to OS 6 is still better.
Alternatively, you can backup the data, transfer the disks to the new NAS and set it up fresh.
HTH
Regards
Sinegraf
Jul 07, 2019Guide
It feels like the safest way is to take a 5TB USB disk, make a backup.
Check the backup so "everything" is included
move the disks to a 214.
format and redo.
Unless everything is included in the backup, I can try to migrate the information
- StephenBJul 08, 2019Guru - Experienced User
That would only work if the backup button was already provisioned to back up the full NAS (since you have no network interface you won't be able to set that up now). If no jobs were set up for the backup button, then pressing it does nothing.
I would back up the system first if you can. But I wouldn't start over with a factory default on the new NAS unless that was actually needed. So I'd look in the log zip file first, and see if there any disk or btrfs errors in system.log or kernel.log. I'd also look at the SMART settings in disk_info.log If I saw something, then I probably would start over.
Note that you can make a backup after you migrate to the RN214 (and you should certainly put a backup plan in place).
- SinegrafJul 14, 2019Guide
StephenB wrote:
Sinegraf wrote:It feels like the safest way is to take a 5TB USB disk, make a backup.
I have done a "test backup", the first terrabite .. (now I had no bigger USB disk). Now I do not remember if I put any restrictions on which boxes for USB backup.. is the "normal setting" -everything??
system.log / kernel.log file, do i find them in the USB backup?
I know the SMART data was good on the disks just before the crash..
PS.
-we have two NAS's. Our primary work NAS is still alive.. Then we have offline Backblaze storage..
But this NAS was our "Basement" which work as 'online backup' to the "primary work NAS", and where you put everything big that is not defensible to have in the cloud. so as in your basement there are larger dumps that "can be good to have" ;)
But everything "important" is on the first NAS, which now has no inhouse backup..- StephenBJul 14, 2019Guru - Experienced User
Looking over this thread again, I think the easiest way to extract the data is to connect the hard drives to a Windows PC and use RAID recovery software (using either SATA or a USB adapter/dock). R-Studio should work and is inexpensive. https://www.r-studio.com/
There is no normal setting, so it would depend on what backup job you created and tied to the backup button.
Do you recall if you have an NV+ v1 (4.1.x firmware) or an NV+ v2 (5.3.x firmware)? You won't be able to use the 5 TB drive with the NV+ v1, as it doesn't support GPT formatting.
Easy ways to tell:
An NV+ v1
- says "NV+" on the front chassis
- has an internal power supply
An NV+ v2
- says "NV+ v2" on the front chassis.
- has a power adapter
I know the SMART data was good on the disks just before the crash..System.log and kernel.log won't be on the USB backup. They are downloaded from the NAS using a different mechanism.
Note I forgot that you were migrating from an NV+. The only way you could follow my advice on system.log/kernel.log would be to migrate to a used NV+ (and there you'd be looking for ext file system errors, not btrfs). Also, you'd have to reformat the drives on the OS-6 NAS.
