ludovit8
Mar 31, 2013Aspirant
No raid or raid 0
Hi, I have raid 1. How can I disable raid to make raid 0? I found topic here, that I can make disable raid by setting up raid 0. OK. But how can I set raid 0 :-)? Can I do it from admin panel or...
Mar 31, 2013Guru - Experienced User
You need to do a factory default procedure. The easiest way is to have only one disk installed when you do that. You have 10 minutes to set the mode to flexraid (which you do with RAIDar on a PC). Once the setup is complete you can insert the second disk and add a new volume.
This will wipe your data and settings, so you need to have a full backup.
Is your duo a v1 (4.1.x firmware) or a v2 (5.x.x firmware)?
