ludovit8
Mar 31, 2013Aspirant
No raid or raid 0
Hi, I have raid 1. How can I disable raid to make raid 0? I found topic here, that I can make disable raid by setting up raid 0. OK. But how can I set raid 0 :-)? Can I do it from admin panel or...
ludovit8
You need to do a factory default procedure. The easiest way is to have only one disk installed when you do that. You have 10 minutes to set the mode to flexraid (which you do with RAIDar on a PC). Once the setup is complete you can insert the second disk and add a new volume.
hm... I do a factory procedure, I have there just one disk pluged in. NAS started ok, everything works. Then I turn it off and plug in second disk.
Nas was doing something about 30 minutes, it makes also sound :-) and now it is calm down, quite and blue disk LED is blinking (raider says bad disks detected).
I will wait till morning but if it will still blinking what can I do better with next try ?
Can I do factory reset and have there two HDD, will I have still posibility set up raid 0 ?
