ludovit8
Mar 31, 2013Aspirant
No raid or raid 0
Hi, I have raid 1. How can I disable raid to make raid 0? I found topic here, that I can make disable raid by setting up raid 0. OK. But how can I set raid 0 :-)? Can I do it from admin panel or...
Mar 31, 2013Guru - Experienced User
There was no need to power down. Was this a normal shutdown?
You can start with both disks in place, though it is easy to get a single volume spanning both drives by mistake. One at a time prevents that.
