ludovit8
Mar 31, 2013Aspirant
No raid or raid 0
Hi, I have raid 1. How can I disable raid to make raid 0? I found topic here, that I can make disable raid by setting up raid 0. OK. But how can I set raid 0 :-)? Can I do it from admin panel or...
ludovit8
normal...
ok, if my current try will fail, can you give me steps what to do at the morning - next try ?
1. make factory procedure
2. during turn off status, plug in both disks
3. turn it on
4. then what ???? it will ask me on type of raid and I will choose 0, or it will automaticaly make raid 1 ??
3. turn it on
