ludovit8
Mar 31, 2013Aspirant
No raid or raid 0
Hi, I have raid 1. How can I disable raid to make raid 0? I found topic here, that I can make disable raid by setting up raid 0. OK. But how can I set raid 0 :-)? Can I do it from admin panel or...
Mar 31, 2013Guru - Experienced User
If you can insert the disks into a PC, you can delete the partitions with Windows Disk manager. Then you'd start with a clean set.
I would then power up the NAS with just one disk installed, and select flexraid. Wait for it to come fully up.
Then hot-insert the second disk, and add a new volume.
