xm813
Nov 08, 2022Aspirant
No Shares Currently Accessible
Hello, ReadyNAS has been sitting on the shelf for a little while after I moved. Tried to login and only get this: Logged in as admin. Have seen a couple of these on the forum bu...
Nov 09, 2022Guru - Experienced User
xm813 wrote:ReadyNAS has been sitting on the shelf for a little while after I moved. Tried to login and only get this:
Browse to http://192.168.1.243/admin
If you leave out the /admin bit you will end up redirected to http://192.168.1.243/shares - and if you haven't enabled shares for http access, you will end up with a blank page.
xm813
Nov 09, 2022Aspirant
Added /admin and now get this:
I can select the items on the left but nothing appears in the middle.
