xm813
Nov 08, 2022Aspirant
No Shares Currently Accessible
Hello, ReadyNAS has been sitting on the shelf for a little while after I moved. Tried to login and only get this: Logged in as admin. Have seen a couple of these on the forum bu...
Nov 08, 2022Guru - Experienced User
Do you see any shares if you browse to \\192.168.1.243 in file explorer? (Make sure you use the correct slash).
xm813
Now I just get the first image above:
No shares currently accessible.
- StephenBNov 08, 2022Guru - Experienced User
Then you either used the wrong slash ( // instead of \\), or you were using the browser instead of file explorer.
- xm813Nov 08, 2022Aspirant
A-Ha
I misread your post. So using Finder instead of a browser I am able to see the actual files. But still nothing on the Frontview
- StephenBNov 09, 2022Guru - Experienced User
ok. 4.2.22 firmware dates back to 2012 (the final 4.2.x firmware was 4.2.31). So one possibility is that there is a browser incompatibility. FWIW, it is a bit surprising you are able to connect to frontview at all, since most browsers have deprecated TLS 1.0, which is all that your NAS can use.
So one path is to download an old version of firefox, and see if you can access frontview with it. Do you recall about when the last time you were able to access was?
Also, do you have a backup of the data on the NAS? Another path is to do a factory default, which would destroy the data.
