aequus
Aug 13, 2015Aspirant
No snapshot on RN104
Hi, I have latest OS on my NAS and enabled for several shares daily snapshots. None of them work; I disabled and enabled snapshots again but with same result. Trying to create a manual snapshot I rec...
- Aug 13, 2015
Volumes > 16TB are not yet supported on the 104 (support is coming in 6.4 - not yet available). And before 6.4 snapshots do not work with volumes >16TB on 32-bit systems. That is why your snapshots are not working.
It will work in 6.4, but you should create a fresh volume on that as your current one would already be corrupted.
mdgm-ntgr
Aug 13, 2015NETGEAR Employee Retired
- aequusAug 13, 2015Aspirant
Q1: at the moment where at 6.2.5 how long will it take till 6.4?
Q2: Would snapshots work with actual OS on RN204, RN304?
- mdgm-ntgrAug 13, 2015NETGEAR Employee Retired
Q1. Can't give an ETA, but keep an eye on the forums.
Q2. Wouldn't work on 6.3.5 (current firmware for the RN204) but if you install a few packages from 6.4 on 6.3.5 it should work on the 204 (it still won't work on the 104 on 6.3.x as we don't support volumes> 16TB on the 104 till 6.4). It is working for one user on a RN204 running 6.3.5 with the few select packages installed.
The RN314 is not a 32-bit system so it will work fine on that on current firmware. It would also work fine on your RN516.- aequusAug 13, 2015Aspirant
Î use RN104 only for backup resons; the admin page shows vol data with 10TB free of 29TB in total. It seems to be > 16TB, or?
