aequus
Aug 13, 2015Aspirant
No snapshot on RN104
Hi, I have latest OS on my NAS and enabled for several shares daily snapshots. None of them work; I disabled and enabled snapshots again but with same result. Trying to create a manual snapshot I rec...
- Aug 13, 2015
Volumes > 16TB are not yet supported on the 104 (support is coming in 6.4 - not yet available). And before 6.4 snapshots do not work with volumes >16TB on 32-bit systems. That is why your snapshots are not working.
It will work in 6.4, but you should create a fresh volume on that as your current one would already be corrupted.
mdgm-ntgr
Aug 13, 2015NETGEAR Employee Retired
aequus
Q1: at the moment where at 6.2.5 how long will it take till 6.4?
Q2: Would snapshots work with actual OS on RN204, RN304?
