Westyfield2
Apr 21, 2019Tutor
No Volume Exists - Remove inactive volumes in order to use the disk
Hi,
Running v6.9.3
After a reboot the NAS came up saying "No Volume Exists".
Have done another couple of shutdowns and startups and it's now saying "Remove inactive volumes to use the disk....
Westyfield2
Apr 25, 2019Tutor
admin@NAS:/$ lsblk NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINT sda 8:0 0 1.8T 0 disk ├─sda1 8:1 0 4G 0 part │ └─md0 9:0 0 4G 0 raid1 / ├─sda2 8:2 0 512M 0 part │ └─md1 9:1 0 2G 0 raid6 [SWAP] └─sda3 8:3 0 1.8T 0 part └─md126 9:126 0 9.1T 0 raid5 sdb 8:16 0 5.5T 0 disk ├─sdb1 8:17 0 4G 0 part │ └─md0 9:0 0 4G 0 raid1 / ├─sdb2 8:18 0 512M 0 part │ └─md1 9:1 0 2G 0 raid6 [SWAP] ├─sdb3 8:19 0 1.8T 0 part │ └─md126 9:126 0 9.1T 0 raid5 ├─sdb4 8:20 0 1.8T 0 part │ └─md125 9:125 0 3.7T 0 raid5 └─sdb5 8:21 0 1.8T 0 part └─md127 9:127 0 1.8T 0 raid1 sdc 8:32 0 5.5T 0 disk ├─sdc1 8:33 0 4G 0 part │ └─md0 9:0 0 4G 0 raid1 / ├─sdc2 8:34 0 512M 0 part │ └─md1 9:1 0 2G 0 raid6 [SWAP] ├─sdc3 8:35 0 1.8T 0 part │ └─md126 9:126 0 9.1T 0 raid5 ├─sdc4 8:36 0 1.8T 0 part │ └─md125 9:125 0 3.7T 0 raid5 └─sdc5 8:37 0 1.8T 0 part └─md127 9:127 0 1.8T 0 raid1 sdd 8:48 0 1.8T 0 disk ├─sdd1 8:49 0 4G 0 part │ └─md0 9:0 0 4G 0 raid1 / ├─sdd2 8:50 0 512M 0 part │ └─md1 9:1 0 2G 0 raid6 [SWAP] └─sdd3 8:51 0 1.8T 0 part └─md126 9:126 0 9.1T 0 raid5 sde 8:64 0 1.8T 0 disk ├─sde1 8:65 0 4G 0 part │ └─md0 9:0 0 4G 0 raid1 / ├─sde2 8:66 0 512M 0 part │ └─md1 9:1 0 2G 0 raid6 [SWAP] └─sde3 8:67 0 1.8T 0 part └─md126 9:126 0 9.1T 0 raid5 sdf 8:80 0 3.7T 0 disk ├─sdf1 8:81 0 4G 0 part │ └─md0 9:0 0 4G 0 raid1 / ├─sdf2 8:82 0 512M 0 part │ └─md1 9:1 0 2G 0 raid6 [SWAP] ├─sdf3 8:83 0 1.8T 0 part │ └─md126 9:126 0 9.1T 0 raid5 └─sdf4 8:84 0 1.8T 0 part └─md125 9:125 0 3.7T 0 raid5
Sandshark
Apr 25, 2019Sensei
OK, I just recently went though this exercise. See How-to-recover-from-Remove-inactive-volumes-error.
I see your drives, in order of bays 1-6 are 2TB, 6TB, 6TB, 2TB, 2TB, 3TB. These form three RAID layers, md127, md126, and md125. All the RAIDs seem intact, but the BTRFS file system didn't mount. If this differs from what you believe you have, then the rest of this is not going to work.
Try using cat /proc/mdstat to verify all the RAID layers are healthy. If any are re-syncing, let them finish. Next, mdadm --detail /dev/md127 (and md126 and md125), will show you (among other things) the array names, which should be an 8-digit hex host name followed by a colon and data-0, data-1, and data-2, assuming a single, standard XRAID volume named "data". Also do a cat /etc/fstab to see if all your data volumes (which I assume is just the one) are listed. It should look something like this:
LABEL=43f6464e:data /data btrfs defaults 0 0
If all looks right, then mount --all should be all you need.
If the RAID layers don't have the right names, then you are going to have to re-assemble them with the right ones. I've not gone that far. If fstab doesn't include your data volume, you're going to have to add it. That 8-digit hex code in my example is the host ID again.
Let us know what works, or post anything that looks out of kilter from the commands I listed.
- Westyfield2Apr 26, 2019Tutor
Looks like md125 isn't happy.
cat /proc/mdstat Personalities : [raid0] [raid1] [raid10] [raid6] [raid5] [raid4] md125 : active raid5 sdc4[0] sdb4[2] sdf4[1] 3906749824 blocks super 1.2 level 5, 64k chunk, algorithm 2 [3/3] [UUU] md126 : active raid5 sda3[0] sdf3[5] sde3[4] sdd3[3] sdc3[2] sdb3[6] 9743313920 blocks super 1.2 level 5, 64k chunk, algorithm 2 [6/6] [UUUUUU] md127 : active raid1 sdc5[0] sdb5[1] 1953372928 blocks super 1.2 [2/2] [UU] md1 : active raid6 sda2[0] sdf2[5] sde2[4] sdd2[3] sdc2[2] sdb2[1] 2093056 blocks super 1.2 level 6, 512k chunk, algorithm 2 [6/6] [UUUUUU] md0 : active raid1 sda1[0] sdf1[5] sde1[4] sdd1[3] sdc1[2] sdb1[6] 4190208 blocks super 1.2 [6/6] [UUUUUU] unused devices: <none>mdadm --detail /dev/md127 /dev/md127: Version : 1.2 Creation Time : Fri Dec 16 23:36:47 2016 Raid Level : raid1 Array Size : 1953372928 (1862.88 GiB 2000.25 GB) Used Dev Size : 1953372928 (1862.88 GiB 2000.25 GB) Raid Devices : 2 Total Devices : 2 Persistence : Superblock is persistent Update Time : Mon Apr 15 20:35:57 2019 State : clean Active Devices : 2 Working Devices : 2 Failed Devices : 0 Spare Devices : 0 Name : 33eadf27:data-2 (local to host 33eadf27) UUID : a4343df5:9ab3de78:5fa43f83:8f0c56b5 Events : 232 Number Major Minor RaidDevice State 0 8 37 0 active sync /dev/sdc5 1 8 21 1 active sync /dev/sdb5mdadm --detail /dev/md126 /dev/md126: Version : 1.2 Creation Time : Wed Oct 5 18:01:25 2016 Raid Level : raid5 Array Size : 9743313920 (9291.95 GiB 9977.15 GB) Used Dev Size : 1948662784 (1858.39 GiB 1995.43 GB) Raid Devices : 6 Total Devices : 6 Persistence : Superblock is persistent Update Time : Fri Apr 26 16:59:04 2019 State : clean Active Devices : 6 Working Devices : 6 Failed Devices : 0 Spare Devices : 0 Layout : left-symmetric Chunk Size : 64K Name : 33eadf27:data-0 (local to host 33eadf27) UUID : 64c2c473:9f377754:501cbcc3:bf5a752e Events : 1232 Number Major Minor RaidDevice State 0 8 3 0 active sync /dev/sda3 6 8 19 1 active sync /dev/sdb3 2 8 35 2 active sync /dev/sdc3 3 8 51 3 active sync /dev/sdd3 4 8 67 4 active sync /dev/sde3 5 8 83 5 active sync /dev/sdf3mdadm --detail /dev/md125 /dev/md125: Version : 1.2 Creation Time : Wed Oct 5 18:02:22 2016 Raid Level : raid5 Array Size : 3906749824 (3725.77 GiB 4000.51 GB) Used Dev Size : 1953374912 (1862.88 GiB 2000.26 GB) Raid Devices : 3 Total Devices : 3 Persistence : Superblock is persistent Update Time : Fri Apr 26 16:59:04 2019 State : clean Active Devices : 3 Working Devices : 3 Failed Devices : 0 Spare Devices : 0 Layout : left-symmetric Chunk Size : 64K Name : 33eadf27:data-1 (local to host 33eadf27) UUID : 699ba84d:86b18c86:edf75682:8aa9843a Events : 5574 Number Major Minor RaidDevice State 0 8 36 0 active sync /dev/sdc4 1 8 84 1 active sync /dev/sdf4 2 8 20 2 active sync /dev/sdb4cat /etc/fstab LABEL=33eadf27:data /data btrfs defaults 0 0
mount --all mount: /dev/md125: can't read superblock
- SandsharkApr 26, 2019Sensei
You could try stopping and re-assembling md125, but I fear it will do no good. Maybe try booting (read-only would be best to try first) each set of 5 without one of the md125 elements --the 3TB and 6TB's.
- HopchenApr 27, 2019Prodigy
Would you mind giving me a PM with the link for the logs? I will take a look for you.
Cheers
Hi again
The raids themselves are not the issue. All of them are running fine. As you are using different sized disks, the NAS will partition them up and make several raids accordingly. Afterwards, the filesystem will stick these raids together into a single volume. As you can see, volume "data" is expecting 3 devices (your 3 raids).
Label: '33eadf27:data' uuid: 52342247-97af-41fa-b85c-a717370cd941 Total devices 3 FS bytes used 13.11TiB devid 1 size 9.07TiB used 8.64TiB path /dev/md126 devid 2 size 3.64TiB used 3.21TiB path /dev/md125 devid 3 size 1.82TiB used 1.39TiB path /dev/md127
What is actually happening here is that BTRFS makes a JBOD volume out of your 3 raids. This also means that each raid has it's own filesystem on top of it but BTRFS will require all 3 of them to be active in the volume, in order to mount the overall data volume.
As you discovered yourself, md125 has some issues with its filesystem. As a result the entire volume "data" cannot mount and you will see the "inactive volumes" error message.
[Wed Apr 24 19:32:15 2019] BTRFS error (device md125): parent transid verify failed on 9209338265600 wanted 1187338 found 1187336 [Wed Apr 24 19:32:15 2019] BTRFS error (device md125): parent transid verify failed on 9209338265600 wanted 1187338 found 1187336 [Wed Apr 24 19:32:15 2019] BTRFS warning (device md125): failed to read log tree [Wed Apr 24 19:32:15 2019] BTRFS error (device md125): open_ctree failed
The problem with the filesystem on md125 is an inconsistency between the filesystem and the filesystem-journal. The types of issues can usually be combated by simply clearing the filesystem-journal on the affected device.
Here are some links that might be of interest:
https://btrfs.wiki.kernel.org/index.php/Btrfs-zero-log
https://askubuntu.com/questions/157917/how-do-i-recover-a-btrfs-partition-that-will-not-mount
Do a btrfs-zero-log on /dev/md125 and (gracefully) reboot the NAS.
Furthermore, be careful not filling the NAS too much. As with other filesystems, BTRFS does not like being filled up. It seems your volume was very full? I recommend leaving a good 10% free space at all times.
[19/04/13 08:45:15 WEST] info:snapshot:LOGMSG_SNAPSHOT_MONITOR_INFO Snapshot 2019_04_11__00_00_04 was deleted from share or LUN AV due to low free space on the volume. [19/04/13 08:46:15 WEST] info:snapshot:LOGMSG_SNAPSHOT_MONITOR_INFO Snapshot 2019_04_11__00_00_04 was deleted from share or LUN Media due to low free space on the volume. [19/04/13 08:47:15 WEST] info:snapshot:LOGMSG_SNAPSHOT_MONITOR_INFO Snapshot 2019_04_11__00_00_04 was deleted from share or LUN Files due to low free space on the volume.
Cheers
- Westyfield2Apr 27, 2019Tutor
That looks to have done it, thanks.
btrfs-zero-log /dev/md125 WARNING: this utility is deprecated, please use 'btrfs rescue zero-log' parent transid verify failed on 9209338265600 wanted 1187338 found 1187336 parent transid verify failed on 9209338265600 wanted 1187338 found 1187336 parent transid verify failed on 9209338265600 wanted 1187338 found 1187336 Clearing log on /dev/md125, previous log_root 9209338265600, level 0 root@NAS:~#
Taking your point about capaicty, this is what I'm currently on:
13.12TB used of 14.53TB (1.41TB free)
Is there anything I should do to check it's fine before I expand with a bigger drive?
Similarly I've realised that defrag/scrub/balance aren't on a schedule, but how can I check it's safe before I run them?
- HopchenApr 28, 2019Prodigy
Hi again
Glad to hear your volume is back online.
As for the free space. Your volume is fairly large and thus keeping the amount of free space you have reported now is decent enough. I would be vary of going much below 1TiB free space on a volume this size.
I agree that you should do a full check on the health of the NAS at this point. I would recommend the following action, in order:
1. Take a full backup if you not have one already. This is the most important.
2. Get output of current disk stats by running command:
# get_disk_info
You can also get the disk stats from the logs if you like: disk_info.log
Take note of what the disk stats look like here.
3. Run a full disk health check from the GUI. It will take many hours to complete but checks the disks thoroughly. Afterwards, get the disk stats again and compare. Any disks that have increased in errors or showing new errors, replace them first.
4. Run a volume Scrub from the GUI to give the filesystem a full check. It will take a long time to complete as well.
5. Replace to larger disks if you like. Replace one at a time and wait for sync to complete before moving to the next one.
As for balance and defrag. I think a schedule of monthly defrag and balance is fine. I would also recommend doing a disk health check every quarter. A scrub is enough to do every 6 months or so. If your disk health is good and the initial scrub completes fine then you should be good to run scheduled tasks going forward.
Any questions, let me know - Cheers
- StephenBApr 28, 2019Guru - Experienced User
# get_disk_info
There's some additional information if you run
# smartctl -x /dev/sdX
using the actual disk (/dev/sda, etc).
In particular there is an error log for disk commands. I've been seeing some issues with one of my disks - volume reads sometimes time out (for instance, media playback freezes). Nothing shows up in disk_info.log. But when I use smartctl -x I am seeing stuff like this:
Error 324 [11] occurred at disk power-on lifetime: 21495 hours (895 days + 15 hours) When the command that caused the error occurred, the device was active or idle. After command completion occurred, registers were: ER -- ST COUNT LBA_48 LH LM LL DV DC -- -- -- == -- == == == -- -- -- -- -- 40 -- 51 00 00 00 00 00 57 f2 38 40 00 Error: UNC at LBA = 0x0057f238 = 5763640 Commands leading to the command that caused the error were: CR FEATR COUNT LBA_48 LH LM LL DV DC Powered_Up_Time Command/Feature_Name -- == -- == -- == == == -- -- -- -- -- --------------- -------------------- 60 00 48 00 70 00 00 00 57 f2 08 40 08 18d+03:42:08.241 READ FPDMA QUEUED 60 00 b0 00 68 00 00 00 65 16 30 40 08 18d+03:42:08.236 READ FPDMA QUEUED 60 00 20 00 60 00 00 00 35 13 a0 40 08 18d+03:42:08.232 READ FPDMA QUEUED 60 02 30 00 58 00 00 00 64 f4 c8 40 08 18d+03:42:08.232 READ FPDMA QUEUED 60 00 10 00 50 00 00 00 64 f1 e0 40 08 18d+03:42:08.210 READ FPDMA QUEUED
Though I'd expected that a UNC would either increase the reallocated or pending sector count, that doesn't seem to be happening on this particular disk. FWIW, kernel.log shows something like this when these errors occur:
Apr 20 05:27:28 NAS kernel: ata2.00: exception Emask 0x0 SAct 0xe00000 SErr 0x0 action 0x0 Apr 20 05:27:28 NAS kernel: ata2.00: irq_stat 0x40000008 Apr 20 05:27:28 NAS kernel: ata2.00: failed command: READ FPDMA QUEUED Apr 20 05:27:28 NAS kernel: ata2.00: cmd 60/80:a8:c0:f3:3f/01:00:f5:01:00/40 tag 21 ncq 196608 in res 41/40:00:28:f4:3f/00:00:f5:01:00/00 Emask 0x409 (media error) <F> Apr 20 05:27:28 NAS kernel: ata2.00: status: { DRDY ERR } Apr 20 05:27:28 NAS kernel: ata2.00: error: { UNC } Apr 20 05:27:28 NAS kernel: ata2.00: configured for UDMA/133 Apr 20 05:27:28 NAS kernel: sd 1:0:0:0: [sdb] tag#21 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE Apr 20 05:27:28 NAS kernel: sd 1:0:0:0: [sdb] tag#21 Sense Key : Medium Error [current] [descriptor] Apr 20 05:27:28 NAS kernel: sd 1:0:0:0: [sdb] tag#21 Add. Sense: Unrecovered read error - auto reallocate failed Apr 20 05:27:28 NAS kernel: sd 1:0:0:0: [sdb] tag#21 CDB: Read(16) 88 00 00 00 00 01 f5 3f f3 c0 00 00 01 80 00 00 Apr 20 05:27:28 NAS kernel: blk_update_request: I/O error, dev sdb, sector 8409576488 Apr 20 05:27:28 NAS kernel: ata2: EH completeSo the lesson here is that disk issues might not show up in the SMART stats.
FWIW, I will be replacing the disk shortly (as soon as I finish testing the replacement). Then I'll test it more extensively with Lifeguard.
There's no one right answer on this. Personally I do each test once a quarter. Though if a lot of files are changing on your NAS, then I think it does make sense to increase the frequency of balance. Defrag with btrfs is a mixed blessing - while reducing fragmentation will increase transfer speed on the the main shares, it also increases the amount of space used for snapshots. So there is a tradeoff there that you should be mindful of.
FWIW, The scrub also functions as a disk test, since every sector in the data volume is read as part of the test.
- Westyfield2Apr 29, 2019Tutor
Disk tests passed fine, only incremented the power-on-hours and the disk stats now has a self-test Extended offline Completed without error.
sda WDC WD2003FYYS-02W0B0 WD-WMAY01159942 is the only drive to have a single ATA error:
get_disk_info Device: sda Controller: 0 Channel: 0 Model: WDC WD2003FYYS-02W0B0 Serial: WD-WMAY01159942 Firmware: 01.01D01 Class: SATA RPM: 7200 Sectors: 3907029168 Pool: data PoolType: RAID 5 PoolState: 1 PoolHostId: 33eadf27 Health data ATA Error Count: 1 Reallocated Sectors: 0 Reallocation Events: 0 Spin Retry Count: 0 Current Pending Sector Count: 0 Uncorrectable Sector Count: 0 Temperature: 44 Start/Stop Count: 4743 Power-On Hours: 63044 Power Cycle Count: 67 Load Cycle Count: 4719 Device: sdb Controller: 0 Channel: 1 Model: WDC WD6002FRYZ-01WD5B0 Serial: NCHBG8GS Firmware: 01.01M02 Class: SATA RPM: 7200 Sectors: 11721045168 Pool: data PoolType: RAID 5 PoolState: 1 PoolHostId: 33eadf27 Health data ATA Error Count: 0 Reallocated Sectors: 0 Reallocation Events: 0 Spin Retry Count: 0 Current Pending Sector Count: 0 Uncorrectable Sector Count: 0 Temperature: 48 Start/Stop Count: 32 Power-On Hours: 20538 Power Cycle Count: 32 Load Cycle Count: 870 Device: sdc Controller: 0 Channel: 2 Model: WDC WD6002FRYZ-01WD5B0 Serial: NCGWTDVV Firmware: 01.01M02 Class: SATA RPM: 7200 Sectors: 11721045168 Pool: data PoolType: RAID 5 PoolState: 1 PoolHostId: 33eadf27 Health data ATA Error Count: 0 Reallocated Sectors: 0 Reallocation Events: 0 Spin Retry Count: 0 Current Pending Sector Count: 0 Uncorrectable Sector Count: 0 Temperature: 47 Start/Stop Count: 35 Power-On Hours: 22267 Power Cycle Count: 35 Load Cycle Count: 942 Device: sdd Controller: 0 Channel: 3 Model: WDC WD2003FYYS-02W0B1 Serial: WD-WMAY04428148 Firmware: 01.01D02 Class: SATA RPM: 7200 Sectors: 3907029168 Pool: data PoolType: RAID 5 PoolState: 1 PoolHostId: 33eadf27 Health data ATA Error Count: 0 Reallocated Sectors: 0 Reallocation Events: 0 Spin Retry Count: 0 Current Pending Sector Count: 0 Uncorrectable Sector Count: 0 Temperature: 47 Start/Stop Count: 4762 Power-On Hours: 60669 Power Cycle Count: 58 Load Cycle Count: 4739 Device: sde Controller: 0 Channel: 4 Model: WDC WD2003FYYS-02W0B1 Serial: WD-WMAY04905430 Firmware: 01.01D02 Class: SATA RPM: 7200 Sectors: 3907029168 Pool: data PoolType: RAID 5 PoolState: 1 PoolHostId: 33eadf27 Health data ATA Error Count: 0 Reallocated Sectors: 0 Reallocation Events: 0 Spin Retry Count: 0 Current Pending Sector Count: 0 Uncorrectable Sector Count: 0 Temperature: 49 Start/Stop Count: 4321 Power-On Hours: 57003 Power Cycle Count: 56 Load Cycle Count: 4293 Device: sdf Controller: 0 Channel: 5 Model: WDC WD4000F9YZ-09N20L0 Serial: WD-WCC131766520 Firmware: 01.01A01 Class: SATA RPM: 7200 Sectors: 7814037168 Pool: data PoolType: RAID 5 PoolState: 1 PoolHostId: 33eadf27 Health data ATA Error Count: 0 Reallocated Sectors: 0 Reallocation Events: 0 Spin Retry Count: 0 Current Pending Sector Count: 0 Uncorrectable Sector Count: 0 Temperature: 44 Start/Stop Count: 1778 Power-On Hours: 43245 Power Cycle Count: 39 Load Cycle Count: 1757
root@NAS:~# smartctl -x /dev/sda smartctl 6.6 2017-11-05 r4594 [x86_64-linux-4.4.116.x86_64.1] (local build) Copyright (C) 2002-17, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === Model Family: Western Digital RE4 Device Model: WDC WD2003FYYS-02W0B0 Serial Number: WD-WMAY01159942 LU WWN Device Id: 5 0014ee 656594009 Firmware Version: 01.01D01 User Capacity: 2,000,398,934,016 bytes [2.00 TB] Sector Size: 512 bytes logical/physical Rotation Rate: 7200 rpm Device is: In smartctl database [for details use: -P show] ATA Version is: ATA8-ACS (minor revision not indicated) SATA Version is: SATA 2.6, 3.0 Gb/s Local Time is: Mon Apr 29 07:29:35 2019 WEST SMART support is: Available - device has SMART capability. SMART support is: Enabled AAM level is: 254 (maximum performance), recommended: 128 APM level is: 254 (maximum performance) Rd look-ahead is: Enabled Write cache is: Enabled DSN feature is: Unavailable ATA Security is: Disabled, NOT FROZEN [SEC1] Wt Cache Reorder: Enabled === START OF READ SMART DATA SECTION === SMART overall-health self-assessment test result: PASSED General SMART Values: Offline data collection status: (0x84) Offline data collection activity was suspended by an interrupting command from host. Auto Offline Data Collection: Enabled. Self-test execution status: ( 0) The previous self-test routine completed without error or no self-test has ever been run. Total time to complete Offline data collection: (29700) seconds. Offline data collection capabilities: (0x7b) SMART execute Offline immediate. Auto Offline data collection on/off support. Suspend Offline collection upon new command. Offline surface scan supported. Self-test supported. Conveyance Self-test supported. Selective Self-test supported. SMART capabilities: (0x0003) Saves SMART data before entering power-saving mode. Supports SMART auto save timer. Error logging capability: (0x01) Error logging supported. General Purpose Logging supported. Short self-test routine recommended polling time: ( 2) minutes. Extended self-test routine recommended polling time: ( 302) minutes. Conveyance self-test routine recommended polling time: ( 5) minutes. SCT capabilities: (0x303f) SCT Status supported. SCT Error Recovery Control supported. SCT Feature Control supported. SCT Data Table supported. SMART Attributes Data Structure revision number: 16 Vendor Specific SMART Attributes with Thresholds: ID# ATTRIBUTE_NAME FLAGS VALUE WORST THRESH FAIL RAW_VALUE 1 Raw_Read_Error_Rate POSR-K 200 200 051 - 0 3 Spin_Up_Time POS--K 253 253 021 - 8691 4 Start_Stop_Count -O--CK 096 096 000 - 4743 5 Reallocated_Sector_Ct PO--CK 200 200 140 - 0 7 Seek_Error_Rate -OSR-K 200 200 000 - 0 9 Power_On_Hours -O--CK 014 014 000 - 63044 10 Spin_Retry_Count -O--CK 100 100 000 - 0 11 Calibration_Retry_Count -O--CK 100 253 000 - 0 12 Power_Cycle_Count -O--CK 100 100 000 - 67 192 Power-Off_Retract_Count -O--CK 200 200 000 - 23 193 Load_Cycle_Count -O--CK 199 199 000 - 4719 194 Temperature_Celsius -O---K 108 097 000 - 44 196 Reallocated_Event_Count -O--CK 200 200 000 - 0 197 Current_Pending_Sector -O--CK 200 200 000 - 0 198 Offline_Uncorrectable ----CK 200 200 000 - 0 199 UDMA_CRC_Error_Count -O--CK 200 200 000 - 0 200 Multi_Zone_Error_Rate ---R-- 200 200 000 - 1 ||||||_ K auto-keep |||||__ C event count ||||___ R error rate |||____ S speed/performance ||_____ O updated online |______ P prefailure warning General Purpose Log Directory Version 1 SMART Log Directory Version 1 [multi-sector log support] Address Access R/W Size Description 0x00 GPL,SL R/O 1 Log Directory 0x01 SL R/O 1 Summary SMART error log 0x02 SL R/O 5 Comprehensive SMART error log 0x03 GPL R/O 6 Ext. Comprehensive SMART error log 0x06 SL R/O 1 SMART self-test log 0x07 GPL R/O 1 Extended self-test log 0x09 SL R/W 1 Selective self-test log 0x10 GPL R/O 1 NCQ Command Error log 0x11 GPL R/O 1 SATA Phy Event Counters log 0x80-0x9f GPL,SL R/W 16 Host vendor specific log 0xa0-0xa7 GPL,SL VS 16 Device vendor specific log 0xa8-0xb5 GPL,SL VS 1 Device vendor specific log 0xb6 GPL VS 1 Device vendor specific log 0xb7 GPL,SL VS 1 Device vendor specific log 0xbd GPL,SL VS 1 Device vendor specific log 0xc0 GPL,SL VS 1 Device vendor specific log 0xc1 GPL VS 24 Device vendor specific log 0xe0 GPL,SL R/W 1 SCT Command/Status 0xe1 GPL,SL R/W 1 SCT Data Transfer SMART Extended Comprehensive Error Log Version: 1 (6 sectors) Device Error Count: 1 CR = Command Register FEATR = Features Register COUNT = Count (was: Sector Count) Register LBA_48 = Upper bytes of LBA High/Mid/Low Registers ] ATA-8 LH = LBA High (was: Cylinder High) Register ] LBA LM = LBA Mid (was: Cylinder Low) Register ] Register LL = LBA Low (was: Sector Number) Register ] DV = Device (was: Device/Head) Register DC = Device Control Register ER = Error register ST = Status register Powered_Up_Time is measured from power on, and printed as DDd+hh:mm:SS.sss where DD=days, hh=hours, mm=minutes, SS=sec, and sss=millisec. It "wraps" after 49.710 days. Error 1 [0] occurred at disk power-on lifetime: 40806 hours (1700 days + 6 hours) When the command that caused the error occurred, the device was active or idle. After command completion occurred, registers were: ER -- ST COUNT LBA_48 LH LM LL DV DC -- -- -- == -- == == == -- -- -- -- -- 10 -- 51 03 b8 00 00 33 d8 ea c0 40 00 Error: IDNF at LBA = 0x33d8eac0 = 869853888 Commands leading to the command that caused the error were: CR FEATR COUNT LBA_48 LH LM LL DV DC Powered_Up_Time Command/Feature_Name -- == -- == -- == == == -- -- -- -- -- --------------- -------------------- 60 03 b8 00 70 00 00 33 d9 dc c8 40 08 46d+17:24:57.544 READ FPDMA QUEUED 60 02 98 00 68 00 00 33 d9 da 30 40 08 46d+17:24:57.544 READ FPDMA QUEUED 60 00 c8 00 60 00 00 33 d9 d9 68 40 08 46d+17:24:57.543 READ FPDMA QUEUED 61 00 80 00 58 00 00 33 d9 41 c0 40 08 46d+17:24:57.542 WRITE FPDMA QUEUED 61 00 80 00 50 00 00 33 d9 3e c0 40 08 46d+17:24:57.542 WRITE FPDMA QUEUED SMART Extended Self-test Log Version: 1 (1 sectors) Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error # 1 Extended offline Completed without error 00% 63031 - # 2 Short offline Completed without error 00% 5 - # 3 Short offline Completed without error 00% 0 - SMART Selective self-test log data structure revision number 1 SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS 1 0 0 Not_testing 2 0 0 Not_testing 3 0 0 Not_testing 4 0 0 Not_testing 5 0 0 Not_testing Selective self-test flags (0x0): After scanning selected spans, do NOT read-scan remainder of disk. If Selective self-test is pending on power-up, resume after 0 minute delay. SCT Status Version: 3 SCT Version (vendor specific): 258 (0x0102) SCT Support Level: 1 Device State: Active (0) Current Temperature: 44 Celsius Power Cycle Min/Max Temperature: 26/46 Celsius Lifetime Min/Max Temperature: 26/55 Celsius Under/Over Temperature Limit Count: 0/0 SCT Temperature History Version: 2 Temperature Sampling Period: 1 minute Temperature Logging Interval: 1 minute Min/Max recommended Temperature: 0/60 Celsius Min/Max Temperature Limit: -41/85 Celsius Temperature History Size (Index): 478 (228) Index Estimated Time Temperature Celsius 229 2019-04-28 23:32 42 *********************** ... ..( 27 skipped). .. *********************** 257 2019-04-29 00:00 42 *********************** 258 2019-04-29 00:01 43 ************************ ... ..(142 skipped). .. ************************ 401 2019-04-29 02:24 43 ************************ 402 2019-04-29 02:25 44 ************************* ... ..( 7 skipped). .. ************************* 410 2019-04-29 02:33 44 ************************* 411 2019-04-29 02:34 45 ************************** ... ..( 37 skipped). .. ************************** 449 2019-04-29 03:12 45 ************************** 450 2019-04-29 03:13 44 ************************* ... ..( 22 skipped). .. ************************* 473 2019-04-29 03:36 44 ************************* 474 2019-04-29 03:37 43 ************************ ... ..( 57 skipped). .. ************************ 54 2019-04-29 04:35 43 ************************ 55 2019-04-29 04:36 44 ************************* ... ..( 71 skipped). .. ************************* 127 2019-04-29 05:48 44 ************************* 128 2019-04-29 05:49 43 ************************ ... ..( 43 skipped). .. ************************ 172 2019-04-29 06:33 43 ************************ 173 2019-04-29 06:34 44 ************************* ... ..( 36 skipped). .. ************************* 210 2019-04-29 07:11 44 ************************* 211 2019-04-29 07:12 42 *********************** ... ..( 16 skipped). .. *********************** 228 2019-04-29 07:29 42 *********************** SCT Error Recovery Control: Read: 70 (7.0 seconds) Write: 70 (7.0 seconds) Device Statistics (GP/SMART Log 0x04) not supported Pending Defects log (GP Log 0x0c) not supported SATA Phy Event Counters (GP Log 0x11) ID Size Value Description 0x0001 2 0 Command failed due to ICRC error 0x0002 2 0 R_ERR response for data FIS 0x0003 2 0 R_ERR response for device-to-host data FIS 0x0004 2 0 R_ERR response for host-to-device data FIS 0x0005 2 0 R_ERR response for non-data FIS 0x0006 2 0 R_ERR response for device-to-host non-data FIS 0x0007 2 0 R_ERR response for host-to-device non-data FIS 0x000a 2 10 Device-to-host register FISes sent due to a COMRESET 0x000b 2 0 CRC errors within host-to-device FIS 0x8000 4 128983 Vendor specific - StephenBApr 29, 2019Guru - Experienced User
Well, there was this error on sda (perhaps related to the ATA error)
But it occured quite a while ago, so I wouldn't be concerned about it.
Just to follow up on my own smartctl -x issue...
That disk failed Lifeguard's extended test (too many bad sectors), It had 35 days of warranty left, so I started the RMA today.
