dikkiedirk
Jan 26, 2012Aspirant
No write permission on NFS share
I have a NV+ and I have NFS enabled for the default media share. I have mounted this share in my Unraid server with the mount command: mount -t nfs 192.168.xxx.xxx:/media /mnt/netgear I can s...
mdgm-ntgr
Jan 26, 2012NETGEAR Employee Retired
You will need to connect using a UID and GID that matches that on the ReadyNAS. If the UID or GID of the user on your client machine is different then that would most likely be the cause of your problem.
