dikkiedirk
Jan 26, 2012Aspirant
No write permission on NFS share
I have a NV+ and I have NFS enabled for the default media share. I have mounted this share in my Unraid server with the mount command: mount -t nfs 192.168.xxx.xxx:/media /mnt/netgear I can s...
dikkiedirk
Jan 27, 2012Aspirant
mdgm wrote: You will need to connect using a UID and GID that matches that on the ReadyNAS. If the UID or GID of the user on your client machine is different then that would most likely be the cause of your problem.
Can you tell me how to do this? Can I set the UID and GID with the mount command I wrote in the OP above?
