sohaib
Apr 27, 2023Aspirant
NOT able to replace a faulty drive for ReadyNAS 3220, version 6.10.8.
Apr 27, 2023Guru - Experienced User
sohaib: If you want help here, then you will need to give us a lot more details. Starting with the RAID mode you are using, the model/size of the drive that failed, the model/size of the replacement. And whether the NAS is detecting the drive, what (if any) errors you are seeing, etc.
- sohaibApr 27, 2023Aspirant
Hi Dear,
Thanks for your kind response.
Kindly find below the Screen-shot before we started the repairing process , from the below screen shot, you can know the Raid level, No of drives, Type & model of the drives, Data Size & Status.
Screen Shot, before Replacing the drive , OR doing any changes…
Please find below the current status , and the steps which we have done.
2) we have added a new drive in the 10th-bay , planning that , once we add the new drive , we will have more storage/ container size , then we will replace the faulty drive in the 6th-bay….
( As it is RAID-6 we the Storage-size of 7-drives, and 2 (two)-drives are as failover……) (Total No. of drives installed: 9. , so the total space we have is Approx. 26TB.)
3) but , we have noticed, that this drive is NOT building , and its status remain as :UNKNOWN……
4) so, later we have removed this new drive from the 10th bay & replaced it with the faulty drive in the 6th-bay…..
I also formatted the new 6th bat drive , by using the right FORMAT-Tab,
4) it has formatted , and automatically restarted, and the below status of the drives has occurred , as shown below .
5) NOW , I ma sure, that some how the original size of the container (i.e. the 25.44TB is there , but the parity of the Data is somehow manipulated/ changed.
6) maybe , I need to reactivate the HD (1, 5, 8, & 9)…….which turned black….
Finally, do please advice us with your kind feedback.
Thanking you for your kind cooperation.
Sohaib M. Naseem Shakir.
- StephenBApr 27, 2023Guru - Experienced User
Have you downloaded the log zip file?
I'm not sure exactly what you mean by "failover".
Just to clarify, you appear to have 7x4 TB RAID-6, so volume size is 28 TB (about 25 TiB). RAID-6 has dual-redundancy. You don't appear to have any disks as as global spares.
Was the original array using 4 TB drives? Or was it vertically expanded at some point.
A bit confused on this. Are you saying that you
- inserted disk 10
- removed disk 10 (when it didn't seem to be adding)
- removed disk 6
- then put disk 10 in slot disk, selected it, and formatted it?
- sohaibApr 28, 2023Aspirant
Hi Dear,
Yes,
The total No. of Drives are (9-drives).
if Configured With Netgear RAID-X, as raid-6, i will have a storage size of (Seven (7)) Hard drives...
Are you able to see the screen shots....
Please find below the required clarification (to clarify the confusions)
- inserted disk 10 (YES, New drive to expand the Array)
- removed disk 10 (when it didn't seem to be adding), YES
- removed disk 6 (YES , as it is faulty ...as per the Red-LED color.
- then put disk 10 in slot disk, selected it, and formatted it? YES.
