joe_schmo
Mar 05, 2018Tutor
Not expanding after resync...
I had put in a new higher capacity drive... it did its thing: Sun Mar 4 2018 10:04:42 Disk: Disk in channel 3 (eSATA Port 1) changed state from RESYNC to ONLINE. Sun Mar 4 2018 10:04:29 Volume: ...
yxue
Mar 06, 2018NETGEAR Expert
You can click UI>System>Volumes, to see if there is a volume syncing, or you press buttons on front panel to see the LCD, volume syncing will show on LCD
joe_schmo
Mar 06, 2018Tutor
That's the thing, the UI isn't showing anything. I know for a balance, I can use the btrfs commands to check. But what's the command for sync?
Or is there something else that I can do to get it to start syncing?
