Zippyduda
Aug 19, 2021Aspirant
Not seeing option to enable snapshots
On my ReadyNAS RN104 (firmware 6.10..5 Hotfix 1) I do not see any option to enable or disable Snapshots in Share Properties. https://kb.netgear.com/23166/How-do-I-view-and-change-the-properties-of-a-...
- Aug 20, 2021
Zippyduda wrote:
Looks like when I go to enable quotas on a Share it gives me the attached message about quotas being disabled on the volumes.
Leave quotas off on the shares - unless you want to limit the amount of storage in the share for some reason.
Quota on the volume doesn't do what you think it does. It improves the btrfs "accounting" so that the file system has more detailed knowledge of how the space is being used. If you want to see the amount of snapshot space, you do need to enable quota on the volume settings wheel. I do want to see those details, so I have volume quota turned on, but share quotas turned off.
Zippyduda
Aug 20, 2021Aspirant
Thanks Stephen for the detailed reply! Looks like when I go to enable quotas on a Share it gives me the attached message about quotas being disabled on the volumes. I must have done this a while back. I assume I can turn these back on by going to System > Volumes > Cog icon next to the pie chart > Summary > ticking Quota?
Yeah I've disabled Smart snapshots in favour of Custom ones as I remember a while back the snapshots ate all my disk space and I had to delete a ton of them. I also disabled Allow snapshot access for the reasons you mentioned.
Aug 20, 2021Guru - Experienced User
- ZippydudaAug 20, 2021Aspirant
Gotcha :)
Enabling Quota on the Volume is now showing the yellow Snapshots part on System > Volumes and in Shares as well. Thanks Stephen!
