EKroboter
Feb 09, 2017Apprentice
NTP settings not persistent
I can't seem to get a persistent NTP setting. Whenever I click on the Device Time gear icon, the NTP seetting are always unchecked. I enable it, add some ntp servers and a message disaplays that NTP ...
- Mar 02, 2017
Yes, it should all be fixed in 6.7.0, which is currently available as a public beta.
Feb 09, 2017Guru - Experienced User
What firmware are you running? Is there a specific NTP server you are trying to use?
EKroboter
Runing 6.6.1 but I've seen this behavior since forever.
I use these NTP servers:
0.ar.pool.ntp.org 1.south-america.pool.ntp.org 3.south-america.pool.ntp.org
- StephenBFeb 09, 2017Guru - Experienced User
0.pool.ntp.org works for me (I'm in the US), as do the built-in netgear time servers.
Do the Netgear time servers also fail (for instance time-e.netgear.com)?
- EKroboterFeb 09, 2017Apprentice
Doesn't matter which one I choose, they all fail. Non of them "sticks". Here's a quick screen grab so can see what I see: http://sendvid.com/0bl6a91k
That is definitely wrong, the synchronize box should remain checked.
You have email alerts working, correct? If so, the NAS is able to reach the internet.
Maybe PM mdgm-ntgr and see if Netgear wants to look at the logs.
