EKroboter
Feb 09, 2017Apprentice
NTP settings not persistent
I can't seem to get a persistent NTP setting. Whenever I click on the Device Time gear icon, the NTP seetting are always unchecked. I enable it, add some ntp servers and a message disaplays that NTP ...
- Mar 02, 2017
Yes, it should all be fixed in 6.7.0, which is currently available as a public beta.
EKroboter
Runing 6.6.1 but I've seen this behavior since forever.
I use these NTP servers:
0.ar.pool.ntp.org 1.south-america.pool.ntp.org 3.south-america.pool.ntp.org
Feb 09, 2017Guru - Experienced User
0.pool.ntp.org works for me (I'm in the US), as do the built-in netgear time servers.
Do the Netgear time servers also fail (for instance time-e.netgear.com)?
- EKroboterFeb 09, 2017Apprentice
Doesn't matter which one I choose, they all fail. Non of them "sticks". Here's a quick screen grab so can see what I see: http://sendvid.com/0bl6a91k
- StephenBFeb 09, 2017Guru - Experienced User
That is definitely wrong, the synchronize box should remain checked.
You have email alerts working, correct? If so, the NAS is able to reach the internet.
Maybe PM mdgm-ntgr and see if Netgear wants to look at the logs.
Yes, email alerts work, and the NAS can access the internet withtout problems.
