EKroboter
Feb 09, 2017Apprentice
NTP settings not persistent
I can't seem to get a persistent NTP setting. Whenever I click on the Device Time gear icon, the NTP seetting are always unchecked. I enable it, add some ntp servers and a message disaplays that NTP ...
- Mar 02, 2017
Yes, it should all be fixed in 6.7.0, which is currently available as a public beta.
jdfoxmicro
Feb 09, 2017Tutor
Hey,
Google is pretty amazing. I typed "readynas ntp settings don't stick" and this thread, posted just today, was first.
I'm setting up an RN3138, and having the exact same issue. It had 6.4.1, and I just updated to 6.6.1, but the same problem. I'm working on it, and I'll post what I find here.
By the way, you might want to reconsider that video sharing site you linked to. It generated a porn popup, something I'm not happy about, certainly on my work computer.
Jeffrey Fox
