EKroboter
Feb 09, 2017Apprentice
NTP settings not persistent
I can't seem to get a persistent NTP setting. Whenever I click on the Device Time gear icon, the NTP seetting are always unchecked. I enable it, add some ntp servers and a message disaplays that NTP ...
- Mar 02, 2017
Yes, it should all be fixed in 6.7.0, which is currently available as a public beta.
EKroboter
Feb 12, 2017Apprentice
Jeffrey, I really appreciate your thoroughness on this. Unfortunatelly as you very well point out, this does not apply to my case. I've tried both internal (DC) and external (npt.org, netgear) NTP servers and none of them stick. The clock syncs, but the setting is not persistent across reboots and the setting is somehow lost everytime I click the gear icon and the modal window appears. This is one of the reasons Im hoilding back on integrating our ReadyNAS to our Active Directory domain, since time sync errors can bring up issues with authentication.
I do believe there is a way to edit the settings manually. Hopefully someone from Netgear sees this and is kind enough to point out where the setting is actually stored.
I'll keep investigating.
mdgm-ntgr
Feb 13, 2017NETGEAR Employee Retired
Did you try what I suggested?
- EKroboterFeb 13, 2017Apprentice
I have. Clear all caches, history and cookies. Re-opwn the browser and go to the admin page and enter NTP settings. Re-open again and delete all history and caches once more. Open up Frontview and the same thing happens: In a split second the box is uncheked and the ntp servers are gone from the list.
- EKroboterFeb 17, 2017Apprentice
Still no resolution to this issue.
- FramerVFeb 20, 2017NETGEAR Employee Retired
Hi EKroboter,
Might be best if you can send your logs for further checking.
How do I add my ReadyNAS OS 6 storage system to my ReadyCLOUD Account?
- EKroboterFeb 20, 2017Apprentice
Logs sent.
Hi EKroboter,
Thanks. Let me inquire about your case.
- SkywalkerFeb 21, 2017NETGEAR Expert
EKroboter, it looks like the last NTP interaction was too long ago, and is no longer in your logs. Can you do a fresh reboot, then try enabling NTP again from the GUI, and send in your logs immediately after that? Alternatively, you can just enable Secure Diagnostic Mode, and PM me the 5-digit code so we can investigate directly.
- EKroboterFeb 21, 2017Apprentice
I'll try to reboot tonight after the backup jobs run, enable NTP and download the logs. Thanks for your help.
- SkywalkerFeb 22, 2017NETGEAR Expert
Great, now can you do one more reboot, then wait 20 minutes and send in one last set of logs?
There are definitely some issues with NTP and clock settings in general in 6.6.x. It should all be fixed in 6.7.0, which is currently available as a public beta. However, even on 6.6.x, it should all work normally after a reboot once you have it configured.
- EKroboterFeb 22, 2017Apprentice
Oh, I'll try again tonight. Can't right now since we have three servers using iSCSI targets and all are being used. Were you able to see anything wrong in the logs I sent?
Based on the logs you sent, the system appears to be configured properly, but in a state where periodic NTP updates won't kick in until after a reboot (or a restart of the connman service).
- EKroboterMar 02, 2017Apprentice
Hmm, I see. I´ll try to do multiple reboots whenever I get a chance. Hopefully this will be fiex in the next update.
- SkywalkerMar 02, 2017NETGEAR Expert
- EKroboterMay 30, 2017Apprentice
Yes! 6.7.1 fixed it for me, and still works after 6.7.4. Rebooted a couple of times and the NTP settings are saved.
Thank you.
