EKroboter
Feb 09, 2017Apprentice
NTP settings not persistent
I can't seem to get a persistent NTP setting. Whenever I click on the Device Time gear icon, the NTP seetting are always unchecked. I enable it, add some ntp servers and a message disaplays that NTP ...
- Mar 02, 2017
Yes, it should all be fixed in 6.7.0, which is currently available as a public beta.
Skywalker
Feb 22, 2017NETGEAR Expert
Great, now can you do one more reboot, then wait 20 minutes and send in one last set of logs?
There are definitely some issues with NTP and clock settings in general in 6.6.x. It should all be fixed in 6.7.0, which is currently available as a public beta. However, even on 6.6.x, it should all work normally after a reboot once you have it configured.
EKroboter
Feb 22, 2017Apprentice
Oh, I'll try again tonight. Can't right now since we have three servers using iSCSI targets and all are being used. Were you able to see anything wrong in the logs I sent?
- SkywalkerFeb 22, 2017NETGEAR Expert
Based on the logs you sent, the system appears to be configured properly, but in a state where periodic NTP updates won't kick in until after a reboot (or a restart of the connman service).
- EKroboterMar 02, 2017Apprentice
Hmm, I see. I´ll try to do multiple reboots whenever I get a chance. Hopefully this will be fiex in the next update.
- SkywalkerMar 02, 2017NETGEAR Expert
- EKroboterMay 30, 2017Apprentice
Yes! 6.7.1 fixed it for me, and still works after 6.7.4. Rebooted a couple of times and the NTP settings are saved.
Thank you.
