gn00347026
Dec 27, 2017Guide
"(null)+0" on RN516 front display
Hi all I have a rn516, it cannot boot up after normal restart. It shown null +0 and the panel Thanks
- Dec 27, 2017
It could be caused by an add-on crashing for example, but that error is very generic so there are a range of possibilities.
Dec 27, 2017Guru - Experienced User
You likely need support via my.netgear.com.
If you purchased your NAS (new) between 1 June 2014 and 31 May 2016, then you have lifetime free chat support.
- gn00347026Dec 27, 2017Guide
Thanks stephen first
but anyone encountered the same issue, can any one give me some hints first?
- StephenBDec 27, 2017Guru - Experienced User
You could try forcibly powering down the NAS, and then restart it. Likely that will work, but the problem might recur.
- mdgm-ntgrDec 27, 2017NETGEAR Employee Retired
